What is vassal?
My Feedback: (15)
What is vassal?
I was reading my April 2011 Model Airplane News and under Tips & Trick I read an article on cleaning glow plugs. It stated in the article to let them soak in Vassal. What is it or is there a US equivalent? The article was from a gentleman in Canada, so it may not be available here. Or was this a typo in the mag? Would like to save a little bit of money on glo plugs if I could clean them and reuse them???
My Feedback: (19)
RE: What is vassal?
I was wondering the same thing. A google search for VASSAL came up with nothing.
But it did find something made by Exxon called Varsol, which is a solvent. I wonder if this is what the MAN glow plug tip was referring to?
Do a google search for VARSOL for more info.
RE: What is vassal?
Varsol is quite common around here... In fact, varsol is quite similar to kerosene, it is some kind of refined petroleum derivate.
It is used as general cleaner, sometimes mixed with floor cleaning products to get rid of black spots left by the shoes etc... and used as light solvent (best thing to get rid of the decals)...
Once in a while I've used it to clean the engines, and while it works good to clean the oil, it is not good to remove castor gunk.
I've cleaned myself the glow plugs when I didn't have anything else to clean the engines...but have not noticed anything special on them after that, but maybe I should give it a try.
saludos,
Jorge
saludos,
Jorge
RE: What is vassal?
I am using sole methanol to clean flament of glow plugs after a good use.Soaking the flament by methanol, I energize the plug heater and blowing slightly onto the reddish flament to make it shine bright really hotlike red.That blow with methanol burns the residue into the cave and flament surface.After some time blowing and several methanol bath,then there will be no residue to burn and flament itself gets old red color though blowing.Then I understand process is finished.
RE: What is vassal?
ORIGINAL: w8ye
In the USA, we know Varsol as Mineral Spirits
It dissolves the bonding agents that allow carbon and other deposits to stick to metals.
For an easy supply, the STP type fuel system additives you pour in you fuel tanks, those type fuel system cleaners are mineral spirits (petroleum distillates) [link=http://www.thecloroxcompany.com/products/msds/armorallstp/stpsuperconcentratedfuelinjectorcleaner.pdf]STP MSDS [/link]
My Feedback: (19)
RE: What is vassal?
Deposits collect on the plug. It will glow with electric current, but the chemical reaction with methanol doesn't occur as efficiently as needed to keep it hot when the engine is running. I highly doubt a solvent will remove any of those deposits.
There are several grades of Varsol. Which did the article recommend?
RE: What is vassal?
When I was a kid working in a service station we kept a vat of salvsol (Mobil's equivalent to Exxon's varsol) for soaking carburetors and the like. It was for all practical purposes a lite kerosene...and smelled like kerosene. It was good to have around for cleaning leather seats or your greasy hands too.
Regards,
Clay
Regards,
Clay
RE: What is vassal?
A glow plug work by the interaction between alchohol and the platinum plating on the glow plug. Once that platinum plating is gone (most plugs are platinum plated, some pure platinum) no amount of cleaning will restore it's function. Now, the plug can also get that plating covered with a coating that prevents the reaction, if that is the case, removeing the coating would help. Just because a glow plug glows, it does not mean it will work as desired. If the plating is covered or gone, no amount of glow will make it work. In most cases, cleaning will not improve the plugs performance. Since platinum is very expensive, few if any glow plugs now are solid platinum. I think Fox was the last company to use solid platinum.
RE: What is vassal?
I have actually had a couple of glow plugs go bad at different times, but they still had a nice coil shape that was undamaged, and they glowed a nice red color when you applied power to them. But the engines would simply not sputter or fire or anything.
RE: What is vassal?
Usually a plug with a poisoned element will start an engine with power to it, but pull plug heat and rpm drops or the engine will quit altogether depending on the state of deterioration.
I too am very skeptical that mineral spirits/Varsol will do anything about baked on deposits on a plug element. If it was that easy we would have known about it a long time ago I think. Cleaning out oil and crud, sure. But how does that get there in the first place expect perhaps in storage.
It's hard to throw out a plug that still glows, but over time I have become ruthless enough that when the standard signs start to show, out with the old and in with the new. But you still run into folks that are determined that if the plug glows there must be something else wrong. I love it when a plug swap vaporizes the problem.
RE: What is vassal?
I keep a little box with my old glow plugs in it. If I have a balky engine, I swap out the plug and put the old one in the box as it is still working. Later when bench running a new or repaired engine, I'll use the old plug first, so that a new good plug isn't fouled out by the stuff in the engine. Sometimes even the ARO or lubrication oil you use in the engine can poison a glow plug element. I tend to run a new or rebuilt engine extra rich for a while to ensure it is lubricated good, before I lean it out and that in itself is pretty hard on a glow plug.
RE: What is vassal?
ORIGINAL: earlwb
I was kinda wondering what voltage was applied when you applied power to the Glow plug? You should use a good volt meter & see if you are getting 1.5 volts. I have noticed that some power panels show a point that is the max current....but sometimes the voltage will be on the low side. You need to have a full 1.5 volts for best glow.
As for cleaning...I soak my used glow plugs in acetone for a few days. It does get the crud off them so the glow will not be covered up ....hopefully letting the plug to work better. Capt,n
RE: What is vassal?
When I was a chemistry college student we used to clean the platinum filament, of some elements test tool, with hot concentrated hydrochloric acid (use rubber gloves beside a fun or inside an aspirating cabin). The filament became shiny like nothing else. Hot concentrated hydrochloric acid dissolves everything (including your lungs), but platinum.
However at this point I have no idea about the performance of your engine.
