YS Dimensions
Old 02-18-2011 | 10:19 AM
Default YS Dimensions
If you own either a YS 140 sport, or a YS 110, could you please provide me accurate size dimensions,(as measured with caliper). If you are familiar with an motor dimension chart,those dimensions would be great. Mainly, the usual suspects-mounting holes crankcase dimensions etc.
Old 02-18-2011 | 02:42 PM
My Feedback: (48)
Default RE: YS Dimensions
Well...I can at least give you the mounting hole dim's.....110/140 front/back center to center =25mm....110 side/side - center to center =52mm....140 side/side - center to center =58mm....
Old 02-22-2011 | 08:42 PM
oskartek's Avatar
Go to the YS support site at
 http://www.ysengines.net/support/manuals/
Then click on the engine of your choice, you will get the manual for that engine including the dimensions you are seeking
Happy flying, Oscar
