Suggested 4 stroke equivalent
What is the profile plane you have?
if it is a 3D type or stunt plane then...
Usually the smaller profile planes are intended to be very light so they have a light wing loading to perform best.
The Saito FA40a actually weights slightly less than a ThunderTiger 36 pro. So it would be a good candidate. The other 4 strokes tend to weigh noticeably more than the 2 stroke engines weigh.
I use a .41 (enya) four stroke on a small acrobat originally designed for a .25 two stroke. <div>11x7 has been the prop of choice.
<div>EXCELLENT!</div></div><div>The best power weight ratio of all my planes over the years... including the pattern stuff.</div><div>I wouldn't bother with anything smaller, you'll love that combo.</div>
My Magnum .30 FS worked OK on my Kadet Jr but it doesnt perform as well as even a bushing .25.
I would say the Saito .40 would be the best compromise, it is built on a .30 size case and well,,, its a Saito.
Is your profile ship a 3D type?
The Saito .40 or O.S. .40 Surpass might be the closest and lightest?
You start getting much bigger in displacement and the wt. goes up significantly.
My Feedback: (66)
As earl started the closest 4 stroke is the Saito 40. it will turn a APC 12x4 at around 11,000 on 30% with a 4-6 ounce tank. The OS 26/30, magnum 30 will not be anywhere close to the same power as the Saito 40. The saito 40 will be down power by a little bit over the .32 Two stroke but not by much. the next up is the Saito 56 but is about 5-7 more ounces in weight and will need a larger engine mount and tank. more weight.
