OS 46AX NO Compression? Help!
Old 04-09-2011 | 09:28 PM
DarZeelon's Avatar
Default RE: OS 46AX NO Compression? Help!
True, Jeff. But at 238 lbs., it will take some time 'til I lighten up...
Those terms I mentioned just don't sound right, even in a hobby atmosphere.
They make their users sound like short-term wannabies, who are incontent with their glow-engine demeanor; and just can't wait to leave it for jets...
Old 04-10-2011 | 03:57 AM
Hobbsy's Avatar
My Feedback: (102)
ORIGINAL: DarZeelon
ORIGINAL: Hobbsy
Dar, I didn't say to set the LS needle with the nose up, set the LS needle on a test stand with the the HS needle peaked. Set the HS needle only on the plane nose up.
Sorry, David.
I thought that's what your wrote.
I must have misread something.
Sorry Dar, clearly I should have been more clear on how to clear up a lean midrange and avoid a conk out.[8D]
At 5' 9" and 205 lbs I guess I'm a light weight.
