Value of this Super Tigre engine
Hard to tell from that small picture what is the condition of the engine. From the general look of it it seems to be from mid 60's to early 70's with that coupled carb/exhaust and Super Tigre had many different r/c engines. It is not rare or special enough to be a collector and too old (in design)to be a user, your best bet would be to look at ebay listings to have an idea of price bracket.
BC, CANADA
It's a G 40 RR R/C. Photos of one similar to it: http://www.rojobcn.com/technic/avion/supertig40.htm
ORIGINAL: neofun_trainer
Do you have his presentations of other Super Tigre engines? Specifically the S90? Thanks.
Sincerely, Richard
You mean this one:
http://www.rojobcn.com/technic/avion/supertis90.htm
Plenty more in here:
http://www.rojobcn.com/indexmotores.htm
S. 90 R/C
Fabricante Micromeccanica Saturno, Bologna, Italia
Distribuido por Micromeccanica Saturno, Bologna, Italia
Serie / Num. Serie s/n
Año de fabricación 1985
Cilindrada 14,73 c.c. (0,899 cu. in.)
Diámetro 27,5 mm. (1,083 in.)
Carrera 24,8 mm. (0,976 in.)
Clase de encendido Glow
Tiempos 2
Tipo de carburador Regulable (Con regulación de velocidad)
Admisión Válvula rotativa delantera
Cojinete interior Si
Cojinete exterior Si
Cigüeñal sobre cárter Si
Cigüeñal sobre bronce No
Combustible Metanol/Aceite
Estado de conservación Nuevo en caja
Comentarios De las últimas series fabricadas en Italia antes de trasladar la producción a China. Carter en dos piezas y culata de base cuadrada. Transferencia tipo schneurle. El grupo es de acero con pistón de aluminio que monta un aro de compresión/engrase. Cigüeñal sobre dos cojinetes de bolas y carburador tipo Mag 6.
Tiempos 2
My Feedback: (16)
The S90 has a round machined head and the top is dished in.
There are pictures here . . . . http://www.rcgroups.com/forums/showthread.php?t=1416888
The link rojobcn is wrong!
Here is another link for the S90 http://cgi.ebay.ie/ws/eBayISAPI.dll?...m=290545115506
The head on the S90K is the same as on a G90
My vintage Como 90 has the muffler shown on the RCGroups listing. The muffler shown on the ebay listing is the swing muffler I have seen fitted to later G models. Was the swing muffler fitted to the vintage S90, or is the ebay offering using the newer style as a replacement?
Thanks. I love my Como!
Sincerely, Richard
Sincerely, Richard
