Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Use of shielded bearings inside engine >
Old 04-15-2002 | 12:38 PM
Default Use of shielded bearings inside engine
The rear bearing had some rust in it (didn't closed the carb). I replaced it with a closed shielded bearing. Any bad?
Grtz Pieter
Old 04-15-2002 | 02:09 PM
I avoid shielded bearings on the rear, but actually they should be just fine and lub with no problems.
