ringed engines
Old 08-16-2003 | 02:58 PM
My Feedback: (38)
Default ringed engines
how can you tell if the ring is stuck on a ringed engine? thats been sitting for along time.
thanks
dan
Old 08-17-2003 | 12:08 AM
vonJaerschky's Avatar
The most obious sign would be a lack of compression when you turn the engine over.
Old 08-20-2003 | 07:02 PM
Default Stuck rings
If it's a 2 stroke get the muffler off so u can see the piston/ring thru the port .when u rock the crank back & forth. See if oil is squishing out the top & bottom ( between the ring & piston
If its stuck no squish.
