Need Engine Break-In Suggestions
PA
I have a brand new ASP FS61AR (ringed) 4-stroke and would like to know the best way to break it in.
What little the "owners manual" says is that it basically only needs a brief bench run and that the low speed needle valve is factory set but may need minor adjustments.
I have closed the main NV and opened it 1-1/2 turns (as per instructions) and have run about 3/4 of a tank (10oz) thru it varying the throttle to simulate flying (if that makes sense).
I am turning and APC 11x7 and just want to make sure that I am doing this right. If any of you engine experts have some words of wisdon to share, I would really apprecaite it.
PA
Thanks gents for the input. I ran a little over a tank thru it and its going in the plane. I am suprised to hear that it should be run rich. Being as a 4S supposedly doesn't need as much lube as a 2S, I would think that running it rich would not allow the ring to seat properly with all the extra lube. But, since I am still learning, I will tune it for max rpm then richen it 3-4 clicks. That should be sufficient?
My Feedback: (182)
A two/four stroke engine with a ringed piston needs a slow, very rich break-in period to properly seat the ring. Typically I will run through a gallon of fuel on the bench with this type of engine. Some will say this is a waste of time/fuel...so be it. I'd bet you have 'dead-sticks' with a new engine you just 'put on the plane and run it', too. I NEVER have dead-sticks...period! A good bench break-in allows you to get the engine properly adjusted and tuned in order to run flawlessly once in the air.
Different strokes for different folks though.
My Feedback: (21)
Originally posted by Cyclic Hardover
That will open up a can of worms. I just break it in on the plane. Fly it on the rich side and go. Bench running is fine but to me is a waste of time.
....let her rip.....
Hello!
Just run it a little rich ...in the airplane.
A 11x7 is a little to small prop for this engine, you better use a 12x7 or a 13x5-13x6 APC.
Regards!
Jan K
Sweden
Regards!
Jan K
Sweden
