YS .91 Supercharged mixture problems
My Feedback: (41)
Hi all,
I have a YS .91 supercharged engine that I am having trouble with and hope someone can help me. I have a 14x6 prop on it, running 20/20 byron fuel and I have a fuel filter and pressure port check valve installed. I get the engine running, run about half throttle and adjust the fuel regulator until it runs stable, then I bring the throttle to full open postion and adjust the hi speed needle valve until just a touch rich and it runs stable, bring it back to idle and let it idle for a few seconds and get it stable. Then I roll the throttle to full throttle and it runs great for about 45 seconds then it sounds like someone is throttleing back and forth, down and up down and up, any hi speed mixture control adjustments seems useless, when I shut it down after that, it sits and pukes fuel from the carb..... Any thoughts??
Dennis
Dennis
ORIGINAL: Bipenut49
Hi all,
Dennis
Hi all,
Dennis
I had surging with the check valve on the pressure line to the tank, and the engine would only run WOT with the check valve on the fuel feed line to the carb (because it would puke fuel out the carb if the barrel wasnt closed and wouldn't throttle worth snot without quitting.)
Just my 2 cents.
Bipenut49,
Start with a fresh YS 4stroke or a OS type F glow plug, NOT! a brand X.
I've had this problem before.
Also be sure the check valve is genuine YS, none of the others will work right.
(theYS is the one with the little flapper not a ball and spring)
Be sure the regulator is absolutely clean.
If you have bottomed out the regulator screw then you have probably damaged something
in the regulator, replace the spring, plunger, and related pieces.
http://www.centralhobbies.com/
Talk to petec in the YS support forum here on RCU, he knows his stuff!
Happy flying, Oscar
Edit; Fuel pouring from the carb after shutdown usually means the regulator is not closing off the fuel.
I suspect you have a damaged plunger, spring, or diaphragm.
Or possibly some kind of crap in the regulator.
This website can help troubleshoot.
http://www.geistware.com/rcmodeling/index.htm
Go to the section on YS engines.
Good luck!
Happy flying, Oscar
Good luck!
