Irvine engines
RE: Irvine engines
Question all All my 53s are UK made, I think OS made some changes?? bore and stroke so if so, the piston and liner of the OS made will NOT FIT the UK version??
am I right on this one?? martin
and head if so
maybe to make things simple will parts interchange with the OS and UK made Irvine 53 MRKll ??
and head if so
RE: Irvine engines
OS changed the bore and stroke which means the crankshaft, piston, liner and head aren't interchangeable and it's likely there's a different conrod as well because of the different stroke. The crankcase was altered so an OS carb could be fitted and the muffler is different but I don't know if they kept the same mount spacing. I'm fairly sure they kept the same prop nut but other than that....... .
RE: Irvine engines
If replacement parts for the new OSvines would fit the older Irvines then people would just fix their old(amazing, awesome, excellent English) one and not buy a new engine.
TX
RE: Irvine engines
ORIGINAL: fiery
Replacement parts for UK made Irvines are still largely available from Ripmax in the UK.
#31
RE: Irvine engines
It looks like Irvine as we knew it is gone, Its now only a name on a red cased OS varient, really quite sad it went down that way, if I wanted an OS I would buy one. Irvine messed up on this one they should have gone an OEM contract with OS to retain as their originals,,, martin
#32
TX
RE: Irvine engines
ORIGINAL: AMB
#33
RE: Irvine engines
TEXAS DON Irvine messed up on this one, When supre tiger moved their manufacturing from Italy to China they went there and set it up, spent months at it, result same engine same quality, maybe Irvine should have done the same with the same company ST did. it would have assured they would be the same, no parts issue. OS wants to sell their engines big is not always better martin
Footnote I have Irvine 40s and 53s all wear Davis diesel heads, yes Davis had a run of his diesel heads for the irvine 40 diesel great upgrade
I also bought some metal backplates for the 40s from Just engines, when they still had some and ditched the plastic ones
#34
RE: Irvine engines
I know it's easy for us to say that Irvine messed up but we don't know the financial state of the company or whatever other reason for the sale of Irvine to OS. It's quite possible that Irvine were on the verge of liquidation and OS found out about it and made them an offer too good to refuse which then enabled OS to make and sell an engine with a highly reputable name. And this is all speculation too .
#36
RE: Irvine engines
As far as I know OS does not own Irvine. I beleive that Ripmax owns them. The owners of Irvine engines, decided to contract with OS to manufacture parts for the Irvine engines. I was thinking that OS made the parts but the engines were assembled in the UK, but after a while itchanged, I think they manufacture them inJapan now. I don't have a "new" Irvine engine, so i can't say what they stamped or molded into the crankcase as to its origin of manufacture. Maybe someone can look at their new engine and let us know.
#39
RE: Irvine engines
Don
Ripmax are a main distributor for various brands and tend not to sell direct to the public.
I order through a UK vendor (i.e. www.rcmodelcentre.co.uk) when I need a part stocked by Ripmax.
Give the vendor the part no., and see if they can assist. I bought an Irvine 40D Tommy Bar (in stock at Ripmax) that way
Some carb parts are shown here:
http://www2.ripmax.net/Category_List...0&Brand=Irvine
A general search on the Ripmax site under "Irvine" will reveal more.
Carb throttle stop screw here (page 37)
Part No: X-IRVCJ-1267
Name: Stop Screw/Spring Assembly
Price: £1.75
I will look for a .40 parts list for you to see if can locate some numbers.
Cheers
Price: £1.75
Cheers
#40
TX
RE: Irvine engines
fiery,
The numbers will do the trick for me once I have them. I understood from the first visit to their website that Ripmax was a wholesaler but they are mentioned prominently on RCG as a source that individuals have obtained parts from. I don't expect to hear back from them. Really good news: Just Engines returned my last email. They're waiting for parts numbers from me to fill my order. I'm getting closer.
[quote]
AMB
[quote]
Inquiring minds want to know. Which metal back plate fits?
[quote]
AMB
[quote]
#41
RE: Irvine engines
Don, for the Irvine .40 Carb.
The quantity for all pieces is one (1) each.
Part No Description
S-CJ-1235 Needle (main jet)
S-CJ-1200 Main Jet
S-CJ-1201 Needle Valve Assembly
S-CJ-1112 Body assembly
S-CJ-1255B Cam Screw
S-CJ-1179 Barrel
S-CJ-1245 Throttle arm
S-CJ-1240 Barrel nut
S-CJ-1250 Secondary needle
S-CJ-1282 Spring clip
S-CJ-1277 Fuel nipple assembly
S-CJ-1270 Barrel spring
S-CJ-SK006 Overhaul kit
My engine list give the part number for the complete carburetor as p/n S-CJ-1850.
"O" rings will be in the overheaul kit.
Part No: X-IRVCJ-SK006
Name: Carb. Overhaul Kit - Jetstream
Price: £2.25
Look at page 40 in the Ripmax listing and click on the part no. It suits your carb.
Part No Description
S-CJ-1200 Main Jet
S-CJ-1179 Barrel
Price: £2.25
#42
TX
RE: Irvine engines
fiery,
No doubt about it. You're my HERO! I've just sent off an email to Andrew at Just Engines requesting the parts. Due to the time lag, Idon't expect to hear back from him until tomorrow. I have saved the items in a document for future use. Would it be possible for you to scan the list and send it to me as a .pdf email attachment? I'm collecting documentation for this engine since I started with nothing. I assume that the rest of the engine parts are on the same list in case I ever need a piston, rod, liner etc.
Don
Don
#44
RE: Irvine engines
I used to work at a power sports dealer wrenching on motorcycles ATV's and snowmobiles. We had an assortment of tiny o-rings used in the mentioned carburetors. You night want to check with your local dealer.
Ken
Ken
#45
RE: Irvine engines
I have always used motor cycle/power sports/auto carb "O" rings when rebulding R/C carbs. I have never bought a genuine spare. Cost of post etc makes it exhorbitant. I now have a little "O" ring collection of my own which lives in an old plastic 35mm film canister. I always buy half a dozen of whatever "O" ring I need due to low cost of the item.
If the substituted "O" ring is just slightly over sized, I install it on the needle. Using the needle as as a mandrel, with a twirling motion I very gently sand the outer edge with my finest grade glasspaper (which I lightly wet with synth model lubricant) until it fits in the housing snugly. Don't use a lot of pressure or the "O" ring may spin on the needle groove. Take it slow.
When done often the seal is better than with the original "O" ring. I lube the ring and inner housing with a thin smear of rubber friendly (brake) grease or a little model engine lubricant to ease the "O" ring in.
#46
TX
RE: Irvine engines
Anyone who claims to be a modeler should be able to make just about anything he needs. Within reason. I'm not averse to altering an O-ring originally intended for another application. That has always been my back up plan in fact. I hoped that by starting this thread, ideas would flow as well as information and I certainly haven't been disappointed. I have been in touch with Just Engines and the parts I need are being assembled by them. I've been advised that they will invoice me when the parts are ready and once paid for, will ship them promptly. That is major progress on this issue from where I started. Additionally, I have found a number of parts that will fit my engines and some that won't. I can't thank all of you enough for your ideas and contributions. I now have a focused plan for obtaining and cataloging some spares that are likely to be needed to keep my examples of these fine engines running for years to come.
One additional thought on the OS produced engines. I doubt that OS secured the rights to the Irvine line just so they could keep things going like they were. They would of course, alter the engines significantly to fit their production processes and marketing vision. Lack of carry over in the parts fitment for older models is a basic tool that any manufacturer will employ to render previous engine versions obsolete. The bad news for us in that approach is that the easy days of ordering exactly the item we need, when needed is at an end. The good news is that all of the modelers who want instant gratification will very quickly decide that their engines are near valueless because of lack of parts availability and dump them. We will be the long term beneficiaries of that activity by buying up spare engines as parts donors. It's part of the process I suppose.
#47
RE: Irvine engines
WoW! Thanks for this. I bought an Irvine .40 in 1991. Flew it for a few years and put it away. Took it down fron the attic last year and it started right up and had no rust. (pickled with CorrosonX).
ORIGINAL: fiery
Part No Description
S-CJ-1200 Main Jet
S-CJ-1179 Barrel
Price: £2.25
Part No Description
S-CJ-1200 Main Jet
S-CJ-1179 Barrel
Price: £2.25
#48
My Feedback: (102)
RE: Irvine engines
Irvine fans, as Fiery alluded to a few post back he and I have done some "horse" er engine trading, I just received an early Irvine "bumpy port" .40 in fine shape. Pictures show where the endearing nick name comes from. I'll run it in a day or two, can't have an engine that you don't run.
#49
TX
RE: Irvine engines
I've seen these offered for sale on fleabay. What is the purpose of the bump? I've also received my parts from JustEngines.com and now have two excellent examples of the non bumpy port .40 engines. I also found that the low speed needle O-ring from a Super Tigre G51 carb fits the Irvine low speed needle perfectly.
#50
My Feedback: (102)
RE: Irvine engines
OK, I ran it a few minutes ago for about 55 minutes, I had to open the LS needle about one full turn and close the HS needle about 4 turns
Engine Irvine .40MKII
Plug===Fox Miracle
Prop==Graupner 12x5
Fuel===WildCat 5% with 18% syn/castor blend and 3 oz castor added
Max rpm===11,441
Idle======1,925 with 1,850 doable for about 30 seconds and then it begins to miss and threatens to quit. Once the needles were set there was no fourstroking or stumbling at all. Acceleration is nearly instantaneous. I ran it with a Mac's 90 sized tuned Quiet Pipe which does not effect the rpm one way or the other, it just makes it very quiet. You can see the coupler in this picture.
Plug===Fox Miracle
Prop==Graupner 12x5
Max rpm===11,441
