Sport and 3d 46 class engine??
Ihave to agree about the bearings. Iwouldnt want to risk an obviously powerful 46 on a bearing failure and they are not terribly expensive or difficult to install.
When I think about it, if someone didn't want to use a Fox engine, then the K&B .45 Sportster is worth a look. It doesn't use ball bearings on the crankshaft, but it is a strong runner, and likes to turn larger props than many two stroke engines do, more like a 4 stroke engine. So it would work well with big low pitch props. it also uses a 1/4x28 prop shaft stub so if you crash and bend the end, you can unscrew it and replace it. Plus it is still made in the USA too. I haven't tried one but the MECOA .46 Aero looks pretty promising too. http://www.mecoa.com/
ORIGINAL: jeffie8696
I have to agree about the bearings. I wouldnt want to risk an obviously powerful 46 on a bearing failure and they are not terribly expensive or difficult to install.
Does anyone know if there is a true chrome plated liner from another engine that will fit the TT Pro 46? I was going to get a piston and liner to have as a spare but figured its worth finding a true chrome one that fits if there is one.
