Nipple tapped into the venturi
RE: Nipple tapped into the venturi
G'day
Some free flight models use a "flood off" system to rapidly stop the engine at the end of a timed flight.
I have also seen team race engines with primers though usually they are set up to squirt fuel on the piston.
I have a Saito four stroke radial which has a primer nipple on the carby and it is very handy when the engine is inside a cowl.
Mike in Oz
Mike in Oz
