What inverted muffler will fit the ASP 1.80 2 strokes
Hi there !
I'm looking for a BCM or other brand compact inverted muffler that will fit a ASP 1.80 2 strokes engine.
The engine will be mounted head down on a Phoenix Cessna AG Wagon ARF.
Any suggestion will be highly appreciated !
George
George
RE: What inverted muffler will fit the ASP 1.80 2 strokes
The screw holes on the engine are about 44mm apart, the screw holes on the adapter are about 58mm apart, center to center.
The OS 1.60FX uses the 44mm screw spacing as does the OS BGX-3500 and the SuperTigre G4500 too.
So that would give you several Bisson mufflers to choose from if you are wanting one of them.
I haven't figured out what engine uses a 58mm screw spacing yet, but maybe it is a Moki or Mark engine like the 1.80 or 2.10 or something.
