Testing the new NV (Norvel) .40 size (6.5cc) gasoline glow engine
#726
RE: Testing the new NV (Norvel) .40 size (6.5cc) gasoline glow engine
ORIGINAL: psgugrad
This technology is to RC engines what the Windows Operating System is to personal computers.
#728
ORIGINAL: blw
A lot of people who have been around computers for some time would not take that as a positive comparison!
ORIGINAL: psgugrad
#729
We had some test vehicles that used computers with Windows 95. Now that's putting your life in danger!!!!
#730
ORIGINAL: Sport_Pilot
I would think 14% castor oil is actually more slop then 20% synthetic castor mix.
ORIGINAL: psgugrad
It's also the slop that you don't have to clean off of the plane when you're done. Anyhow, I guess time will tell who's right
#731
I got my norvel for the cool factor . For those with more engines coming out their Kazoo then they know what to do with this is something different . I have enough engines in just about all the different sizes both 2 and 4 stroke that Im interested in so from now on I will probably just get the ones that hold a interest for me and this engine fits the bill perfectly and at a reasonable cost as well . Im just waiting like Husky for the 60 size version . Cheers the pope
#732
Phoenex
I don't think it's intentional misinformation. There are a lot of things that just aren't apparent until you are actually using it. So when I notice that there is less slime and it's easier to clean up at the field, it occurs to me that gas is a natural de-slimer. By that I mean that I could take a rag soaked in gas and wipe down my glow planes and it would work great. So then it seems natural to figure that less of the gas/oil mix would stick to the plane and what did would be easier to clean up. Add that to the fact that you are burning 1/3 less and it all makes sese. But these things don't naturaly occur to us at the drawing board.
#733
Hi hllywdb
just a quick question . In the manual in regards to the cold break in they refer to turning the engine over 100 times now I presume this is a quick flip of the prop and not a slow turning while holding of the prop . Got my fuel mixed today so wont be long now , mines going on the phonex scanner . Cheers the pope
#734
ORIGINAL: the pope
#735
ORIGINAL: hllywdb
Sure, but you didn't have to push a paper clip into the radio to get you key to eject from the ignition
I did have a key stuck in the ignition of a new car once. Was in the service and had to leave the car at the airfield that way for a week! Got back late at night. Had to hitchhike home for a spare key, bum a ride back to open the car to get it to the shop. Kinda like a Windows experience now that I think about it.
#736
the pope
With the glow plug removed, add some thin oil to the cylinder. Flip it over normally, but DO NOT try to go slow through TDC. NV motors have a good "pinch" at the top when new and can stick at TDC. If this happens, (most likely it won't) just heat the cylinder up with your heat gun and flip it the rest of the way through.
#737
ORIGINAL: JimInCA
I have to disagree with you as well. Being someone who flies mostly 40 to 50 sized glow, I'm very interested in this engine. And I have friends who also have expressed an interest in the engine.
Jim...
Jim...
Also I do not fly regularly so I don't use enough fuel for economy to be a factor. It is the equipment costs that matter to me not fuel.
#738
ORIGINAL: blw
ORIGINAL: psgugrad
Typically those that refer to Windows as Win Doze!
#739
I know that pulling 2 to 3 times more glow fuel through an engine than gas slims up the airframe big time. We have the same situation with fuel costs, glow engines pull 2 to 3 times more fuel through the engine so even if gas and your homemade glow fuel were the same cost per gallon, gas is much more economical to use. Misinformation helps no one and reflects poorly on you.
This is not misinformation, it is fact. I am comparing methanol to gas. You are the one misinforming by trying to add nitro to the mix!
#740
I don't know what power you're looking for but 13,500 rpm on a 10-7 is damn good for a 40 sport engine in my book. If you don't own one how can you comment on its power output? Dont like it don't buy one,don't slam the power output if you know nothiing about what your talking about. Stick with your nitro engines. I personaly am impressed with this engine. Are you jellous that you can't afford to by this engine? Maybe we can start a collection here to help you afford a GX-40 of your very own. I'll start with $2.00
#743
ORIGINAL: toolmaker7341
Actually I am here on this thread because I am intreged by this engine. If I had money I would buy one to try it out, but I do not right now, and when I do this will be a low priority. Both this and the glow version look like very good and very powerful engines for the fuel they use.
#744
Now a longer prop stud is not really needed, as the engines used the standard prop stud for many years and no one considered it a problem. So it is not really a problem. But I made myself a longer 6mm propeller shaft stud for the NV GX 40 engine. You can either make one using a lathe or buy a threaded stud online from many sources and cut it down to length as needed. This is just a personal preference of mine for using a spinner and propeller on the engine.
#745
I also did a bit of machining to the muffler to get the muffler mounting screws to fit better with less risk of the screw heads breaking off.
#746
ORIGINAL: earlwb
#747
Actually no other brand mufflers fit the engines that I know of. They have about a 31.5mm screw spacing for the muffler screws. The OS 25LA and 25FP mufflers come close though. But it isn't difficult to make a bridge adapter to fit most any muffler though. Depending on the muffler used the adapter can be a once piece or two piece type.
#749
Well one can use a hacksaw, a drill and some drill bits and some hand files to make an adapter. If needed the special tools would be a tap for 6x32 screws if you need to thread some holes. But a drill press is handy of course and if you have it then you can use a milling machine to good effect too. One can get creative on finding some aluminum bar stock etc to use. You can usually find something that can make a 1 inch or so wide and about 3/8 inch thick adapter piece or pieces.
If the muffler screws do not interfere with each other, you can use a single piece of metal to adapt the muffler to the engine. But if the muffler screws interfere then you need a two piece adapter.
Here is one I made for a Rossi engine to use a Performance Specialties Ultrathrust tuned muffler on it. In this case each adapter half is bolted to the engine and muffler and then bolted to each other.
Now if you have a more thick piece of metal you can make a once piece offset adapter too. This works for some engines. The exhaust passage is angled to mate up with the engine and muffler. This is another Rossi engine adapter shown here as made by RossiEngines USA.
Here is another adapter I made for a Fox 45 to use a K&B muffler.
#750
The Jett Engineering muffler adapters look similar to the Rossi adapter you show. It is a one-piece adapter that offsets the muffler up or down (I can't remember). Those type are a little fancier and would require special tools, I believe. The 2-piece you show can use aluminum strips that you can buy from a hardware store like Lowes or Home Depot. I fabricated a spacer for the NV muffler a couple of months ago using the aluminum bar stock and a drill. Let's just say that it did not come out looking as "purdy" as your adapters.[&o]
I also noticed that a nice feature to the 2-piece adapter idea is that you can set it up to bolt together from either side of the engine (muffler side or engine side).
