Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
 HELP!!!.......i've been away for a while >
Old 09-12-2003 | 09:56 PM
Default HELP!!!.......i've been away for a while
the forum has changed while i was away
where do i go to post that i'm looking for a piston and ring for my engine?
Old 09-12-2003 | 11:00 PM
AMB
Default RE: HELP!!!.......i've been away for a while
Think you really should get it new;;depending on which engine the distributor will have
it go to their website if old and out of production then post it here
Old 09-12-2003 | 11:05 PM
w8ye's Avatar
My Feedback: (16)
Go up above to where you see market place. You will get a pull down window. Select classifieds, then engines and then like 2 stroke glow. Look to the middle left and you will see parts. But you will also see a zero there. No one's put anything in there yet.
Enjoy using RCU
Jim
Old 09-13-2003 | 11:06 PM
thanks
i just checked it but am confused on how to post in there
sorry to be such a pain
Old 09-14-2003 | 12:35 AM
w8ye's Avatar
My Feedback: (16)
If you get into the classifieds, there is an extensive help file that should answer most of your questions but it will require some study.
Most of the new system on the buyers side can be the same as in the old system. There's a easy to use E-mail system for concealed offers that wasn't there before.
The seller's functions have changed considerable though and will require a little reading.
I hope you continue to enjoy using RCU
Jim
