Old Engine
Old 02-10-2013 | 09:54 AM
Default Old Engine
I have an old HPI engine and the flywheel and piston wont budge. What should i do?
Old 02-10-2013 | 10:05 AM
controlliner's Avatar
Default RE: Old Engine
heat it up with a hair dryer. the piston is probably stuck at top dead center.
Old 02-10-2013 | 10:09 AM
ThumbSkull's Avatar
My Feedback: (57)
Put some fuel in the exhaust port and carb, then heat it up to about 200 degrees with a heat gun or blow dryer. Should loosen right up.
Old 02-10-2013 | 11:40 AM
jeffie8696's Avatar
And the car engine forums are probably more familiar with HPIengines, for future reference.
Old 02-10-2013 | 02:15 PM
ORIGINAL: ThumbSkull
If the heat gun ignites the fuel, it could end badly[:@]
Old 02-11-2013 | 08:28 AM
1QwkSport2.5r's Avatar
Is the flywheel tight against the block or is there a slight gap? Bad collets can cause problems.
