repainting an engine
ORIGINAL: rye
Hi can not fine anything under that
If you can find the colors you want in NHT paints, clean the parts in Dawn Power Desolver & let them soak overnight in vineger to etch the surface.
Apply VHT paint, let it dry, then bake it in the oven @ 300°F for a few hours.
I have used Rustolem flat aluminum BBQ paint W/good results on the case. It has stood up well to 30% nitro fuel.
Unfortunately it only comes in (flat) black aluminum & dark green.
My Feedback: (24)
Here I am.
To change the color it would be best to remove the old paint first. There are a number of ways to do this. All of them will require stripping the engine down completely to its bare components.
I have used Dawn Power Dissolver to clean parts but I do not know if it will strip paint. I know brake fluid will strip paint. Or any number of regular "paint stripper" chemicals at the home depot type stores.
Once you have the old paint stripped, make sure you have the parts clean and grease free. Wash in solvent or denatured alcohol.
You need to mask the areas you do not want the paint to get into. This takes time and precision with an Xacto knife. Use toothpicks, q-tips, sacrificial screws, etc to plug screw holes.
I like to paint the hole engine case at one time. Because painting one side first, and then the other makes for uneven finishes. So sometimes I will use wire and hold the engine up by the wire while I spray all around it.
Once the paint is satisfactory, and dry, I bake it in an oven for one hour at 250°F after removing any masking tapes. Then I shut the oven off, leaving the painted parts inside and just let it all cool down for a few hours to room temp. Baking the paint helps cure it and make it harder.
I use Duplicolor automotive engine enamel with ceramic.
Hi tom long time no see.Thanks for reposting those pix like dave says the bright orange one is really good.Did'nt know you could make an old open rocker saito look that good but wish it was one colour say..bright orange!.Do you remember how much time you spent polishing? and i can forward an address if your cabinet gets too full
My Feedback: (24)
Old, sorry but the engines are red. Perhaps your monitor needs a color adjustment?
As for time spent, all I can remember is hours and hours. And, since I have done several engines now, it is hundreds and hundreds of hours.
I like the two-tone colors schemes the best on the vintage looking engines. On more modern designs a one color job looks pretty good.
My Feedback: (13)
MN
Do you ever run the engines after you paint them?
Does the paint reduce the cooling effect of the air?
I would think that it would have some insulating properties, compared to just the raw aluminum.
Greg
Greg
