Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
 Need power increase in multi-engine setup >
Old 09-23-2003 | 11:00 AM
Default Need power increase in multi-engine setup
I am trying to find out what engines are suggested to replace multiple OS 120 Surpass II engines? I want to keep size and weight increases to a minimum, but maximum thrust is very important as well.
Regards,
Al Parry !QUOT!Eaglewatch!QUOT!
[email protected]
Old 09-23-2003 | 07:09 PM
AMB
Default RE: Need power increase in multi-engine setup
You might want to check with davis diesel on this one. one or the larger 1.08 and up
OS or super tigers might fill the bill,
Old 09-23-2003 | 08:45 PM
Al:
Toss the OS's and install Saito 1.50 engines. Weight about the same, fuel consumption not a lot higher, but the power will be raised nicely.
Bill.
Old 09-24-2003 | 09:10 AM
SwampFlier-RCU's Avatar
Irvine 1.50's you won't be disapointed!!
Old 09-24-2003 | 10:38 AM
Forget The Saito 150s unless u plan on doing in flight refueling. Those Saitos drink fuel like u wouldn`t believe. Best bet is 2s diesel. They will swing over a tree with no problem in a smaller size for a longer time on less fuel. Now how is that for losing weight. eg you can use 2 75s diesels and get the same power as the 120s Fs or use 91s diesel 2s and get more power than the 120 Fs. All using no more that 8 oz tanks that will last about 20 mins or more depend on your settings .
Old 09-24-2003 | 10:46 AM
Hobbsy's Avatar
My Feedback: (102)
That is absolutely false about the Saitos. When set up correctly they don't burn any more than others their size. I have about 12 Diesels and know that two .75s would not come aywhere near the power he's looking for, two Webra 120s with Davis heads would be more like it.
