evolution .46 glo plug ?
Yes I have noticed 4 strokes tend to stumble less on transition. however most beginners cant or wont spring for a 4S engine on their trainer. Even used 4S engines command a premium price. These days I get all my used engines from my friend Bruce at brucercengines.com , he tests each used engine and gives them a rating so you know what you are getting. I help him do it from time to time, goes a lot quicker with two people.
That is the trouble Evolutions have with OS 8 range plugs, they load up quickly and have a hard time burning off the fuel. They can be very hard to throttle up after cranking. I had to nurse the throttle up, ease off, nudge it up some more, etc until it finally would run. You can tune a lot of that out with a meticulously set low speed needle, which you need to do anyway. But, it still needs a hotter plug. I'm going to try a MC 59 the next time I see one. I'm slowly getting away from 2 strokes.
The MC14 and MC4C are for 4-cycles and helicopters (the MC4C is a standard long reach plug, no protruding "nose"), MC55 and MC59 are for low and low-med nitro fuels. I venture to guess the 14 and 4C are the hottest followed by the 55 and then the 59. I liked the Enya 3 better than the MC4C in my Enya 4-strokes. Lower idle and better top rpm. The 59 didn't fair as well in the 4-strokes but did work okay. Idle rpm needed to be a little faster.
You should try some of the Merlin offerings you may like them. The 2003HD is my goto hot plug for 2 strokes while the 2009 is my 4 stroke plug. And he has such a wonderful selection of plugs that you would be hard pressed not to find exactly what you need. He even has Cox/Norvel and Nelson.
#33
I bought a few Merlin plugs to try, but without any markings on them it is near impossible to find a suitable plugs once they have come out of their packing....
#37
I used a standard long reach "Merlin" hot plug with success on an old Taipan Mk 4 2.5 cc glow two stroke. Nice plug. It has a 'red' insulator seal.
I rarely use O.S. plugs now. Nice enough but the intermediate length fits very few engines perfectly. Pricing is also high.
