Super Tigre .61 Dead Stick Problems
![](/forum/images/badges/premium_member.png)
Hello 1QwkSport2.5r
One of the issues I've seen with Super Tigre's beside people not knowing about the mid-range fuel adjust and using to high of nitro is the schnuerle ported engines are bad about fuel squinching the glow plug.
With these problems address they are every bit as powerful, long lasting as any other engine out there and a whole lot lower in price.
Merry Christmas
Merry Christmas
Who'd have thought an idle bar plug would run better in a 4-cycle than the heavily pushed OS F plug? Works good for me!
Are you bench testing with the same fuel tank as you are running in the plane...I also noticed that you have a Morris Hobbies Su-Do-khoi which i think the fuel tank is inside the wing or mounted between the wing and the engine..Make sure you're clunk is free enough and flexable enough to swirl around the rear of the tank on all sides...and another thing to check is the distance from the clunk inside the fuel tank to the Carb..About 7" is the most a non pumped 2 stroke will push fuel to run the engine reliable at full throttle. There are exhaust systems you can get that will boost the pressure a bit, like Jett Or Nelson Mufflers, but come with an expense..Hope this helps
I have 3 61's and a 45. They are good running engines. The mystery screw in the throttle linkage arm probably needs to be opened up slightly. It is very sensetive. Use a 1/8" flat screwdriver and turn it CCW about 1/16 of a turn. Keep trying until you get it right. I use Fox Idle bar glow plugs and they work fine. Use a 12-6 or a 11-7 prop.
Larry Kopecky
Conyers, Georgia
Larry Kopecky
Conyers, Georgia
