OS FS 110a dismantling problems
The good people at Just Engines found me a 6mm gudgeon pin from another engine that fitted fine and some cap screws for the rocker cover. I also got the bearings from my local supplier and I put it all back together this afternoon.
It fired up easily, sounded fine and was doing nearly 10k RPM on a 15 x 6
A good result and all for about 20 dollars
Dennis
There is a sort of wire circlip at the front end and a PTFE (I assume) pad at the rear
Thanks again for the response;
Dennis
On this particular model the gudgeon (wrist) pin is tubular but with a web across in the middle. There is a small (2mm approx) hole at the front of the crankcase and I used a piece of piano wire against the web to push it through and out of the bigger hole at the back.
I have never seen a pin with a web like this and that is where the original one snapped - makes you think !
#32
a plastic pad -PTFE?
not very nice weather here but I managed four 15 mins flights with this engine in a 1/5 approx scale Bucker Jungmeister - faultless
#35
I have two Jungmeisters both built from what used to be called Complete-a Pac semi kits. They sold packs of plan, cowl, wirework and precut formers and wingribs You had to do the rest. CAP has now gone out of business but I think the plans are still available here through Traplet
The red and white one is in the colours of a US acrobatic word champion -I can't remember his name. I built in about 1980. It is now a bit battered but still flying with a Surpass 91
The yellow one I bought about 80% complete for next to nothing at a bring and buy. I finished it in a Swiss Airforce scheme and use to fly it with an old OS90 2 cycle. This proved rather unreliable and I had a number of deadsticks -not all of which ended well.
So I bought the 105a for it, gave it a bit of a makeover and now it flies excellently. the extra power, while not strictly necessary, does give it an edge.
#36
Darn, you guys. I was just getting ready to break out the popcorn and now your getting all nicey nicey on me. Good thing Bax came along and explained it all. Well the weather sucks here too so I guess I have to go back to building.
#37
My Feedback: (29)
Nice looking airplanes, I'm fairly certain that what I have is a CAP kit according to the ligature that came with the kit. A complex build by today's standards. All built up, laminated plywood strips for tail and wing tips, very heavy polyester/chop matt cowl. I'm getting rid of the flat bottom airfoil. This may lead me to incorporate plug in wings and access equipment through the canopy. I'm thinking about 20cc gasser for power. Rapture, no grudges here. We all have a common interest. I realize I spoke without the proper information, I can man up to that.
#38
I am currently repairing one for a friend that broke its back - the plane not the friend
#39
My Feedback: (29)
Yes, I know exactly what you mean. The fus builds somewhat like a Guillows rubber powered model. I'm going to scratch build new wings using the Goldberg Ultimate bipe airfoil. What does yours weigh? I'm looking to get mine down to 8 lbs. I eventually will be pulling a new mold from the cowl so I can make one much lighter. Other then that everything else is stock outline but with lightening holes in all the bulkheads. So far a pretty light build.
