os open rocker
Old 11-09-2014 | 07:23 PM
Red face os open rocker
Hi Folk's I recently pulled down a os 60 open rocker which I purchased, to check for rust, there was a little bit in the motor, but when I pulled the back of the engine off, I noticed that there is 3 dot's in the shape of a triangle, I think that they form a upside down triangle, one dot to the bottom. does any one know if this is the correct timing ? any help would be appreciated ! thank you ! Darryl.
Old 11-10-2014 | 07:19 AM
Bax
Those are not "dots". Those are the ends of the screws that hold the assembly together. There should be a small, punched dot on the cam gear. That dot will be at the bottom when the piston is at top dead center.
Old 11-10-2014 | 02:33 PM
thanks for your answer, I placed one , and you are right, they are not dots, they are counter sunk indention's , this is on the back of the motor, that has the gear drive for the pushrod's, to the overhead valves, I checked it with a another motor, and it seem's ok, but we will wait and see when we start it!
Old 11-20-2014 | 12:52 PM
I'm pretty sure Bax is about right because I did the same thing as you did and then said oh crap what about the timing, but what ever the setting was, my engine runs strong!
Old 11-20-2014 | 02:33 PM
Thanks for all your help ! I asked the airborne engineer, from airborne magazine, Brian winch, Brian gave me the full run down on re-assembly! cheers Gents.
