What size fuel line?
I ordered a new OS 1.20 AX yesterday and have not been able to find the correct fuel line size to use with it. Can anyone out there steer me in the right direction? Thanks.
Can't always rely on manuals to show you the way... I have an engine manual that calls the head button a "burn room" and says "do not screw up the cylinder too tight" when installing the head and head button. LoL!
My Feedback: (26)
The ID of the nipple on the carburetor determines fuel flow intake. Match the ID of the fuel tubing and you have answered your question. For those who disagree please explain to me and others why I'm wrong.
My Feedback: (47)
NY
It does seem that engine fuel nipple size would dictate tubing diameter. I haven't ever seen larger Nitro tubing, but with gas the larger tubing will not be snug enough. I'd imagine the same for the Nitro tubing. Are there any size of Nitro engines that call for larger (1/8") tubing?
My Feedback: (66)
the large dia. tubing will cause issues with this engine as it will not be tight enough on the nipple. regular medium fuel line is fine. oh elm I pulled out my fluid dynamic book also and calculated that medium sized fuel line will feed an engine up to 5.21831 HP on a glow engine. so plenty large enough for the 120AX
MT
Just as a side note: I have never had a problem with medium tubing until I bought my 91.... but then again it is the largest engine I have had.
