home made header?
Old 03-17-2016 | 01:37 PM
Default home made header?
I was wondering if anyone has tried to make a homemade exhaust header for 40 to 90 size glow engines. I can make the flange and probably bend the pipe but how are the commercial ones welded up. I have used alumiweld which is like aluminum solder but harder than the parent aluminum material when done. Melts at 700+ degrees so I don't think the exhaust gasses would melt it.
Old 03-17-2016 | 03:13 PM
1QwkSport2.5r's Avatar
Macs Products TIG welds theirs I'm sure. Much cleaner and a far better bond (depth of bond is much better and stronger). If I had the tools to do the work myself, I'd do it so I could say I did... But since I don't, I'll pay the $30 or so for a header. .
Old 03-17-2016 | 07:55 PM
aspeed's Avatar
I tried the alumiweld on a muffler once, and it melted the thinner part, maybe I need more practise. I will stay tuned so I am subscribed.
Old 03-18-2016 | 05:42 AM
Well, I just went through my box of engine parts and found the mufflers I need for my application so I won't pursue this idea at this time. I have been wanting to make a mousse can muffler for a .36 with one of those tin bottle looking coke cans but haven't gotten around to figuring out how I was going to do the header without having to buy it. (I'll end up spending more money making it myself)
Flying season is almost here and I am only 1/4 of the way done with the plane I was supposed to have done this spring. No need to start another project until that is done I guess.
Thanks for information.
Old 03-18-2016 | 07:01 AM
aspeed's Avatar
http://www.spadtothebone.net/SPAD/Mufflers/ I have this site on favourites. Cheaper-sorry, less expensive than a Jett muffler. I have been thinking of making some headers though, mostly for some old Supertigers that have the old heavy muffler with the straight out header that is always broken when i get a used one. I think the mufflers stick forward too far , and they break when crashed, normally taking the back lug off at the same time.
Old 03-18-2016 | 08:16 AM
That is a very nice tutorial. I think I came across that a while back when I was dabbled in combat a little. I might just do that for the 36. I do have a tig welder available from a friend. He said I could use it if I stored it for him. He could teach me how to weld with it in about 10 minutes. I do currently weld but only stick, mig, and oxy/acet. I would really like to learn to tig. It can't be too hard, clean metal, melt metal, add metal, simple as that, right?
Old 03-18-2016 | 09:16 AM
blw's Avatar
blw
can you send pics when you are done? some people have tried this and other parts and some look really, really good.
Old 03-18-2016 | 10:22 AM
pappyd6's Avatar
My Feedback: (21)
Mac's mufflers uses an aluminum brazing rod and flux (I watched Wally make a custom header for a racing engine for my team). The closest thing I have seen on the net is the muggyweld aluminum brazing alloy. I haven't tried it but their videos show a process that was exactly what I observed at Mac's.
Old 03-18-2016 | 10:38 AM
aspeed's Avatar
I tried TIG welding at work. Spent maybe a half hour at it, and they looked pretty good. If you can do nice caulking, then the welds may be OK too. The welder there said they were good too. I dipped the filler rod a bit on the tungsten, and the one welder guy grumbled, but the girl welder was more tolerant. I think the gas motors put out more heat than glow, so maybe brazing is good-if MACs is using it!. We had some furnace brazing at work too. We just TIGed it together for position, and I think there were strips of solder in between where it was needed for the fins and such. It was sent out for that. We pretty much only worked on aluminum. I have been collecting stuff to do some brazing again. I think I just need flux. The guy at work later was a teacher at a nearby college, and he gave me the test to fill out, and I passed the course. Not perfect score, but good enough. I could have just paid the fee, and not even gone to a class?
Old 03-19-2016 | 04:22 PM
Well I just found some aluminum tubing in the scrap pile. Don't know if it's the right size or what grade it is but it looks close and I need to try to bend it now. My friend has a tubing bender so maybe get that done this next week. It will be nice if I can just alumiweld it. If this works out, I want to try to make a mousse can pipe for one of these asp 46 to see what it will do.
