After run oil or Rust?
Old 12-05-2016, 06:37 PM
  #101
Dealspeed
My Feedback: (17)
Dealspeed's Avatar
Originally Posted by hsukaria
The bearing with plastic cover is a "sealed" bearing and the one with the metal cover is a shielded bearing. You want to make sure that enough oil gets to the front bearing. If those seals are going to prevent oil from soaking the front bearing, then I would take the rear side seal out. I don't have any way of telling if the seal will prevent oil from entering the bearing or not. So your call.
I don't think oil will be able to penetrate the front bearing, so I will be removing one of the seals.
Old 12-06-2016, 02:44 AM
  #102
Nitrovein
It will penetrate, it's a shield not a seal on these bearings, no matter if it's metal or rubber.
Old 12-06-2016, 04:42 AM
  #103
Sport_Pilot
Sport_Pilot's Avatar
If it is sealed on both sides then it will have grease in the bearing. If shields then it doesn't matter because the oil will get past the shield, so I would not waste my time, it should work either way.
Old 12-06-2016, 04:51 AM
  #104
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
It will go right through the seals also, Deal, some engines come with the front seals removed, that sounds wrong and backwards but it really works, I've never seen one with a dirty bearing. Fox, MVVS OPS come to mind.
Name:	Front bearings (Small).jpg
Old 12-06-2016, 10:07 AM
  #105
blw
blw's Avatar
I would have run the engine first. You never know how much one will smooth out once the gunk is burned off. The upside is you get to keep all those nicely mated parts together if it isn't excessive rust.
You're right Dave, and I know it, but it sure *seems* wrong to run an engine with the shields removed.
Old 12-06-2016, 10:10 AM
  #106
hsukaria
good to know
Old 12-06-2016, 10:52 AM
  #107
Dealspeed
My Feedback: (17)
Dealspeed's Avatar
I did remove the inner shield, it certainly won't hurt anything to have done so.
Old 12-06-2016, 12:18 PM
  #108
1QwkSport2.5r
1QwkSport2.5r's Avatar
If the engine came from the factory with the front seal/shield in place and rear seal/shield removed on the front bearing, where is the hurt in installing the new bearing in the same fashion? I personally feel a lot better about having that seal/shield in place out front than not.
Old 12-06-2016, 12:51 PM
  #109
Dealspeed
My Feedback: (17)
Dealspeed's Avatar
That's exactly how I felt, the stock front bearing had no shield on the back side of the bearing, seemed right to me to remove it and just have the outer shield in place
Old 12-06-2016, 04:13 PM
  #110
1QwkSport2.5r
Bearings have a much lower rpm limit (before skidding) when lubricated by grease. They have a higher "redline" when oil lubricated.
I for one always use a front shield or seal. It gives me peace of mind. YMMV.
Old 12-06-2016, 04:28 PM
  #111
Dealspeed
My Feedback: (17)
Dealspeed's Avatar
just for the hell of it, I'm going to remove the shield on the front bearing of my GMS 47, I'll chuck it on the test stand after and see how it runs, I just have to know if it's effected at all.
Old 12-06-2016, 04:57 PM
  #112
hsukaria
The front bearing would benefit from having a shield on the front face to reduce oil leaking out. The old engines didn't have the shielded front bearings, maybe because they weren't available? You had to live with fuel oozing all over. I get that with my old Fox engines.
Old 12-06-2016, 05:01 PM
  #113
Gizmo-RCU
My Feedback: (27)
Shielded bearings have been around forever, like me. Same discussions now as years ago! I always removed the inner on the front and both from the rear. Always has worked well for me.
Old 12-06-2016, 05:58 PM
  #114
hsukaria
That's what I was trying to say, but not as eloquently as you said it.
Old 12-07-2016, 04:35 AM
  #115
Sport_Pilot
Some older engines use a spiral on the shaft in front of the induction port to screw the oil back into the engine. Those probably did not need a shield.
Old 12-11-2016, 12:38 PM
  #116
Dealspeed
My Feedback: (17)
Dealspeed's Avatar
Ok. So the engine that prompted me to start this thread is all wrapped up, I ended up replacing the bearings and piston ring, so I noticed after putting it back together that there was a strange clicking sound, this was happening when the piston was outside of the top of the stroke, so I pull the back plate off and pull the glow plug out, after a minute it was apparent that the con rod had a tiny bit of play, this just isn't right is it?
I see this being a problem, am I right to think so?
On a side note, I went through hell getting the con rod disconnected from the crank, something that is normally very easy.
Old 12-11-2016, 02:11 PM
  #117
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Normal most of the time, remember that the clearance in the big and wrist pin end is exaggerated at tdc and bdc because the crankpin is moving more sideways than up or down. Your big end fit looks good.
Old 12-11-2016, 08:05 PM
  #118
GREG DOE
The click is common, and quite normal. It looks good.
Old 12-12-2016, 08:07 AM
  #119
Dealspeed
My Feedback: (17)
Dealspeed's Avatar
Yea it's basically new again
