OS 7D disassembly
Old 05-25-2017, 11:30 PM
planenutzz
Default OS 7D disassembly
Folks,
I have an OS 7D carb that is fitted to a Supertigre ST2500.
I'm looking to do an overhaul on it but how do you pull the idle mixture adjustment valve out and how does the barrel come out?
thanks
Rgds
P
Old 05-26-2017, 06:30 AM
Bax
Here's the exploded diagram.
Attached Thumbnails OS Carb exploded views - pre 90s.pdf
Old 05-26-2017, 03:11 PM
planenutzz
Bill,
thanks for that mate, much appreciated. Removed the lock screw and barrel came straight out, set screw in the barrel then allowed the mixture valve to be removed.
I've replaced the O-rings on mixture valve and on needle valve plus the body to engine flange o-ring on one of my 7D.
Other one has an plastic arm on the needle valve to allow in flight adjustment of top end mixture. I can't seem to fund any info on what part number it might be for those O-rings. They are very small.
Any info would be appreciated.
cheers
P
Name:	OS 7D remote needle 1.jpg
ID:	2217039   Click image for larger version
Name:	OS 7D remote needle 2.jpg
Old 05-30-2017, 08:45 AM
Bax
We don't have part numbers for the in-flight needle valve. It was discontinued quite a while ago.
