Glow Plug Choice!?!?!?
Good Evening all. I have a question concerning glow plugs. If you use an onboard glow system, does it really matter what glow plug you choose??? The reason that I ask is because you are not relying on the glow plug to retain the heat, hence the use of the onboard glow system. Please let me know your thoughts and reasoning. Thanks...
Jesse Open (01-20-2022)
If you tune the engine correctly and use the proper heat range and reach glow plug, you don’t need onboard glow support. If you insist on using inboard glow, you still need to select the proper reach and heat range glow plug.
I've never used continuous on board glo. I have used momentary at the low end only to make sure an engine does not load up at the bottom end but mostly for remote on board starting. Also I have used it at low end for multi engine.
I have used electronic on demand on board glo where the unit detects when a glo plug is going to foul and turns on byitself. Both systems work better than continuous on board glo
With the momentary systems the on board glo is turned off for proper tuning and because its only momentary when in use you run the same plug as normal.
The following 2 users liked this post by Propworn:
Jesse Open (01-20-2022),
Zabriel (01-30-2022)
when the engine is running we know when an Onboard Glow System is putting power to the glug the plug is burning hotter than without power to it! sO, if you use an onboard glow system that is in constant use threw the whole flight your plug will run very Hot throughout the flight. sO, in that case (I would think) you would maybe want to run a Medium plug, it may last longer in that case than a Hot plug would. remember, it's not the heat that makes the plug stay lit.
Jim
Jim
I have used onboard glow a few times. Always switched off above 1/4 throttle aside from full on for starting. I used it mostly on the old club trainer.
I always used a much colder plug. Glow plugs with throttled four stroke/cycle engines are a compromise. They favor plugs that are hot enough to ensure reliable idle. That heat is not needed nor wanted at higher rpm. The added heat causes us to set the needles on the rich side to control timing which in turn costs rpm loss and a slight gain in fuel consumtion.
With OBG on at idle, we no longer need the hot plug. We can run colder plugs and take advantage of a slight power gain with a bit less fuel burned.
That only works if the plug power is off at speeds above idle!
Some input from the OP on what system is intended to be used would be helpful as to suggest a proper plug, however, typically medium and hot plugs are used. However, I’m not a proponent of onboard glow systems. I may if I ever get into multis or radials. I know those have some caveats. Singles though - most of the time are rocksteady.
Just my heavily taxed 2¢.
No problem. In most cases the OBG is used as a convenience. I set up the club trainer to allow easy hand starts without wires, cables, drivers, starters etc.
Finding the ability to use a colder plug was a plus
The typical "All Speed, All the time" guys have little need for OBG.
Cleaned up the thread, keep it about glow plugs. If your post is gone consider yourself warned, if you took a shot at the site moderation consider yourself on a very short leash.
Note, replies that quoted deleted posts were also removed to remove all the bickering content.
Over the years I half heartedly searched for a, (nearly) universal plug. The closest I came to that was the Fox Miracle plug, it would work in anything from a Super Tigre 4500 to a Saito 30 and an OS 26. Neal Tidy at LASER recommended not using the Fox Miracle in a LASER, they worked perfectly in a LASER 70 and 100. The Miracle was a Miracle worker in an MDS.
