Enya 60-III Model 7033
Hi all,
Can anyone tell me where I can obtain bearings for the Enya 60-III Model 7033 , Also looking for some sort of parts manual.
cheers Mark.
cheers Mark.
Every ball bearing shop can help you with bearings, But see to that you get C3 or C4 specified bearings . Swiss WIB is one of the best bearing manufacturers.
What is it you want to know about the engine? It is a ringed engine and thus need 20% castor oil fuel and preferably 5% nitro and you should run it it on low rews with the throttle fully open.
11x7, 12x6, 13x4 or 13x5" props are the ones I would choose. Best props are RAM, APC and Graupner G-Sonic.
Hi Mark,
Here is a link to an Enya .60-III TV Engine Review by Peter Chinn for Radio Modeler in June 1970. https://sceptreflight.com/Model%20En...-III%20TV.html This may provide some of the information you are looking for. It states the bearings are a 15mm x 32mm 9-ball brass-caged rear bearing and a 9.5mm x 22mm 7-ball steel-caged shielded ball bearing at the front. The Enya parts sheet states the front bearing is 3/8". I measured the front of the crank shaft on my Enya model 7033 as 0.374", which is .001" less than 3/8". The best source of bearings I have found in America for RC engines is Boca Bearings. They generally have listings of engines and then cross reference a variety o bearings that will fit. Try this URL link: https://www.bocabearings.com/parts/Enya-60-Iii They list a chrome steel bearing set for about $15 dollars and they also have much more expensive ceramic bearings too. Unverified assumption is Boca Bearing can ship to Australia. I hope this helps. I love my Enya .60-III and still have the original instructions and the Enya parts list sheet. I am having trouble attaching files in RC Universe. It used to be easy, but now seems I have been blocked. If you need a copy, send me a PM (private message) with your email address and I can scan and send them to you as a PDF file.
Enya .60-III TV instructions and parts list are attached.
Mark,
Attached are the instructions and parts list for the Enya .60-III TV. I had to switch to Edge to be able to attach files again. I hope this helps.
I would entertain trying RCBearings.com instead. I’ve never had an issue with their bearings, and they’re usually cheaper than Boca (Boca and OS to hand in hand for being overpriced IMHO).
Been buying from him for a few years, and he inports Enya parts.
Here is his ebay store
https://www.ebay.com/str/thecontroll....m47492.l74602
If you PM me I can give you another link to contact him as well.
Regards
Mike
