46FX Quiting?
Old 04-28-2002 | 11:12 PM
Default 46FX Quiting?
I pulled my 46FX off my GP stick, and now have in in my Sig SE.
The engine ran great on the stick, but it is causing me problems on my SE. I ran 2 tanks threw in and it ran fine but now it will start up fine and go to full power and then it just dies for no reason. I have tried new plugs, adjusting the high speed needle, and still no effect. I have one line coming form my tank and then a pieace of brass tubbing connecting the other half to the remote needle valve, could this be what is causing the problem. I didnt have this set up on the stick, so I am thinking it might be restricting the fuel somehow? Any Tips
Old 04-29-2002 | 12:33 AM
I would pull out the carb, and clean it out real good, you may have got a peice of debris inside your carb at some point in the carb. Be sure to remove your needle valve and clean that out real good too. Daz...
