Smoke & Moki
RE: Smoke & Moki
I had a smoker on my Moki 1.8 with Bisson muffler (Midwest Extra 300). I bought a "smoke injector" from Gerard - the former Moki importer. The smoke injector is nothing more than a fancy muffler pressure tap - longer with about a 1/16 hole that protrudes into the exhaust path. The "injector" gets mounted (drilled/tapped) in the header part of the muffler as close to the engine as possible. No preheat require. I used a 16 oz. tank with TME smoke pump/checkvalve. Worked great. I tried all kinds of smoke oil and found SuperDri the best.
My Feedback: (68)
RE: Smoke & Moki
ORIGINAL: Gbee
any idea where to get "smoke injector" from? do you have a link handy? thank you
