Help find the right engine
Old 12-26-2003 | 05:56 PM
Default Help find the right engine
Hi!! I am new around here, I am 34 from Denmark and ROOKIE I have a Trainer 60 from Great Planes and it's almost finish'd. Now the big quistion. WHAT ENGINE IS THE BEST for this kit???. I dont care the price I have the OS 61 FX in my mind, Is it to big for the plane, or are there better choices?? I just don't want an underpowered engine
Old 12-26-2003 | 06:03 PM
Default RE: Help find the right engine
OS makes a good reliable engine, 61 is good. I prefer more power than called for in all my planes. in a .60 size plane I use a Super Tigre .75, very reliable, and very fast. I would not recommend going larger than recommended though if you have not been flying long.
Old 12-26-2003 | 06:04 PM
OS makes a good reliable engine, 61 is good. I prefer more power than called for in all my planes. in a .60 size plane I use a Super Tigre .75, very reliable, and very fast. I would not recommend going larger than recommended though if you have not been flying long.]k
Old 12-27-2003 | 03:20 PM
Hej!
Om din modell har en spÀnnvidd pÄ 180-220cm och vÀger omkring 3.5-5kg sÄ Àr det lagom med en 10cc tvÄtakts motor (.60-.61). montera en 13x5 to 14x4 propeller och bara flyg! En propeller 12x6 fungerar ocksÄ bra men de andra ger lugnare flygning.
Vilken motor du vÀljer spelar inte sÄ stor roll idag dÄ alla motorer numera fungerar bra.
OS, TT, MVVS, Webra, Irvine, Super-Tigre, Magnum osv har alla en motor som Àr perfekt för din modell.
Ett tips ! Skaffa en motor som gÄr tyst! BÄde OS, IrvineŽoch MVVS har ljuddÀmpare som gör att motorn gÄr mycket tyst! Tystare Àn en fyrtaktare.
Hello!
If your model has a span of 180cm-220cm, weighting between 3,5-5kg, then a 10cc two-stroke .engine (60-.61) will be perfect! Just put on a 13x5 or 14x4 prop and fly. A 12x6 will work good too but the other props will give you a more relaxed flying model.
Which engine you choose doesn't really matter much as all engines on the marked these days are working good.
Be it OS,TT or any other doesn't really matter, choose whatever you like.
Some advise! Get a quiet engine! OS,Irvine and MVVS have ultra quiet silencers that will make your engine run quieter than a fourstroke.
HĂ€lsningar!
Jan K
Sverige
