H.B. .40 engine questions...
Old 02-06-2004 | 11:47 PM
joelacrane's Avatar
Default H.B. .40 engine questions...
Hey i started digging around in my plane stuff and i found an old German made H.B. .40 engine... Its missing the carb and pipe, and the output shaft is just barely bent. It takes a second to notice it... But its there! I think its been wrecked really hard.
So can i still get parts for it? Is it worth fixing? It has tons plenty of compression. Thanks!
Old 02-07-2004 | 11:52 AM
Default RE: H.B. .40 engine questions...
Mecoa handles everything H.B. or H.P. check with them. www.mecoa.com
Old 02-07-2004 | 11:59 AM
joelacrane's Avatar
If i found a carb could i still run it with that bent shaft?
Old 02-07-2004 | 12:05 PM
I wouldn't recommend that. Vibration will be bad. Especially if you can see if it's bent. Get it striaghtened if you can. Or replace it.
Old 02-07-2004 | 04:56 PM
joelacrane's Avatar
I kind figured that the vibration would just rattle the whole thing apart too... Could i put an O.S. carb on it or something or do i absolutely have to have the stock one?
Old 02-07-2004 | 07:11 PM
RaceCity's Avatar
Joel....
You'll pay as much for an OS carb, as you would the CORRECT carb from MECOA.
Replace the crank as well. It's bent...it's no good...replace it.
If you cheap out on the repairs..you can only expect unsatisfactory results.
'Race
Old 02-07-2004 | 07:54 PM
My Feedback: (10)
Been through this MANY times here...
If the crank is slightly bent, it can easily be straightened but you have to know how to do it, or get someone who does to do it. Save your $$...
AJC
Old 02-07-2004 | 08:48 PM
joelacrane's Avatar
How do i straiten it? I have tons of tools...
Old 02-07-2004 | 09:05 PM
RaceCity's Avatar
Joel...
Not to steal AJ's thunder, but when you bend, and then re-bend a piece of metal...it weakens.
Ya know...there's nothing like a prop turning 12K suddenly making a bee-line for your face.
It's up to you. Cranks are cheaper than surgeons.
'Race
Old 02-07-2004 | 09:16 PM
My Feedback: (10)
No thunder here...
Its simple, if you bend a crank a bit (yes, it requires experience to know when it is a good idea and when its not - ie, too far gone) it will bend back easily and stay there, no weakness.
Come on, if you have a bend 15 or 20 thou, its not like its 45 degrees over.... bend it back and its good to go.
DOnt beleive me, I dont care. Spend your $$.
(ps I hate to have to justify anything, or state my background, etc. Just do what you want... and so will I )
AJC
Old 02-07-2004 | 09:19 PM
My Feedback: (10)
ORIGINAL: joelacrane
Please read these threads:
http://www.rcuniverse.com/forum/m_12...tm.htm#1284496
http://www.rcuniverse.com/forum/m_11...tm.htm#1128631
Later,
AJC
Old 02-07-2004 | 09:22 PM
RaceCity's Avatar
AJ..
No disrespect, but I don't believe the individual in question is of your experience.
Best IMO with a new crank.
'Race
Old 02-07-2004 | 11:52 PM
joelacrane's Avatar
Hahaha my dad IS a doctor! We took it apart tonight and he looked at it (He messed with these things all the time when he was a kid...) and he thinks we may be able to fix it. Dad is a heck of a mechanic! I think well try to fix it...
Old 02-08-2004 | 01:21 AM
My Feedback: (12)
FWIW I bet you could buy a HB crank AND carb for what an OS carb (that might not fit!) will set you back.
