RCV engines-overheating
Have a friend with 3 RCV .60s powering a scale JU-52--He is having trouble with the engines overheating and losing about 600RPM on the top-end--the outboard engines seem to have a large inflow and outflow area for air--Has anyone out there experienced overheating problems with RCV engines and was a solution found?
I have the .90sp which I am installing in a GP Stuka....broken in but no flown yet......they do recommend installation of baffles to direct the air especally over the front bearing area.
I am installing a balsa baffle covered with epoxy in the cowl to help direct the air. Also opening the rear to allow a bigger space to allow the air to escape.
With the cylinder laying down rather than in the airstream some means of redirecting the cooling air must be provided.
My Feedback: (13)
Hello, Reverend.
Congrats on the Hornet's success. Sorry I missed it.
Hadley e-mailed me regarding his problem. I told him he was going to have to baffle/duct those puppies.
Were those cowls resonating again? You left before the maiden last week-end; when he took the cowls off, the engines sounded "normal", instead of like they were going to eat themselves. I just wonder if they are inducing some sort of harmonic vibration...
See ya Sunday.
See ya Sunday.
My Feedback: (21)
Having a large inflow area is not always desirable. You want at least 1-1/2 times as much exit as intake for cooling air. As air gets warmer, it expands considerably.
My Feedback: (13)
We know that.
The problem is the design of these RCV engines. They do not have a cylinder head protruding at a right angle into the air flow.
My bet is that the air is flowing PAST the engines, as opposed to OVER them. Hence, the need for baffles or ducts.
