Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
 How hard is hovering on a 2 stroke engine? >
Old 02-12-2004 | 11:59 AM
Default How hard is hovering on a 2 stroke engine?
I have a OS 46 FX on a Morris Knife (4 lbs 12 oz). It is running a little on the fat side. Will hovering for 3 or 4 minutes at time have bad effects?
Old 02-12-2004 | 12:52 PM
JoeAirPort's Avatar
My Feedback: (41)
Default RE: How hard is hovering on a 2 stroke engine?
You should be fine. At the end of the tank it will be leaner. But you're running a little rich so it's ok.
Joe
Old 02-12-2004 | 01:40 PM
JWN's Avatar
JWN
Community Moderators
My Feedback: (42)
Hovering is no harder on an engine that flying horizontal as long as the engine is not lean. The bearings are designed to handle the load without any problems.
John
Old 02-12-2004 | 07:26 PM
Hovering in one spot for three or four minutes will have the bad effect of you getting bored watching it
