Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
 What can we use to soak engine cases clean? >
Old 02-12-2004 | 04:49 PM
Kmot's Avatar
My Feedback: (24)
Default What can we use to soak engine cases clean?
Back in the day, I used to use carb cleaner. But in California the good stuff that actually worked has been banned and the new stuff is useless.
Anyone know of something commercial that does a good job of dissolving gummed up cases? Also, must not encourage electrolysis as I need to soak a Saito head with the liner in it.
Thanks!
Old 02-12-2004 | 05:46 PM
proptop's Avatar
My Feedback: (8)
Default RE: What can we use to soak engine cases clean?
Have you read in here about the crock-pot full of anti-freeze method? Do a search, and you'll find out it works quite well! Just let it soak in hot (not boiling) anti-freeze over night, and presto, "new" engine...A little scrubbing w/ a tooth brush helps too.
Old 02-12-2004 | 08:57 PM
Kmot's Avatar
My Feedback: (24)
proptop: I just did a search and found all the threads. Wow, that is amazing! Thanks for the tip!
