Smoke
Old 02-13-2004 | 11:46 AM
Default Smoke
Hi, I recently crashed my plane. My O.S. .46 AX got sand all over it. I oppened to clean it and reassembled it again and it works just fine.
When the engine is off, if I turn the engine by hand, I can see smoke getting out of the muffler. Is this normal?
Old 02-13-2004 | 12:08 PM
Default RE: Smoke
yes, normal. depending on how you fuel you probably can see smoking coming out while you are fueling also. (there is smoke in the fuel tank after a run, so adding fuel forces that out pressure line into the exhaust.)
Old 02-13-2004 | 12:57 PM
RaceCity's Avatar
Default RE: Smoke
Yep!
Unhook the pressure line from the muffler, and the smoke will disappear.
(Be sure and hook the pressure line back up...)
It's a non-event. Part and parcel of an exhaust pressurized fuel system.
Don't worry about it.
'Race
Old 02-13-2004 | 01:26 PM
Default RE: Smoke
Ok, thanks!
