The weight of a Saito .91
ND
RE: The weight of a Saito .91
http://www.*********.org/saito.htm here is a place to find out the specs on the saito engines !
My Feedback: (47)
IL
Sarge I just weighed my brand spanking new Saito 91 and it was 20.0 ounces. Mine is the GK version with the velocity stack and the new style muffler. My digital scale is brand new and I have checked it several times and it is also right on. Hope this helps
Fred B
Fred B
My Feedback: (8)
CT
Thanks everybody. The reason I wanted to know about the weight is because it's going on a UltraStick .60 and they tend to be nose heavy and I think with the Saito I might be able to get away with using no or very little weight. I think the Saito is even lighter than a OS .60.
Just as info I just weighted a Saito 100 and with prop nuts, washer, muffler and whatever oil left in it after running on 2 different digital scales and it was 21.2 oz.
Ed M.
Ed M.
ORIGINAL: SARGE
You are therefore saving 1/4 lb
Gents ...Just out of intrest...In the power/weight ratio stakes, (no mufflers, you'd customise this to suit..?) O.S...Saito.. & Y.S....91 size.. guess which one came last...?..you probally knew....i did'nt...![sm=confused.gif]
Just for info if converting grams to Oz.'s the following: take total grams and X that number by .035= total Oz.......
Example 555gramsX.035=19.425oz
Dennis
Dennis
