Engine/Prop Question
Old 02-23-2004 | 06:47 PM
bckyrdbshr's Avatar
My Feedback: (35)
Default Engine/Prop Question
I've got a new Magnum XL-108A and am going to be using a 13x6 APC for break in. I was wondering what would be a good prop to go with after break in?
Old 02-24-2004 | 12:31 AM
Default RE: Engine/Prop Question
well 13x6 is too small for a 108. I use a 13x6 on my OS MAX 61 SF ABC long stroke with a TT standard mufler baffle removed which revs it up to 11,100 rpm.So I think 13x6 will underload this engine.what does the instruction manual says.I suggest atleast a 15x7-8 shoould be used.
Old 02-24-2004 | 12:57 AM
bckyrdbshr's Avatar
My Feedback: (35)
According to the instructions 13x6 break in prop, then for normal use 13x7, 14x6
Old 02-24-2004 | 01:10 AM
Flyboy Dave's Avatar
My Feedback: (21)
The Magnum 1.08 doesn't swing big lumber, nor does it turn many revs.
Dave.
Old 02-24-2004 | 01:34 AM
Then use a 13x6 perhaps they have designed the port timing that way but honestly it is for sure a small prop for 1.20 cu in engine.[8D]
Old 02-24-2004 | 09:50 AM
bckyrdbshr's Avatar
My Feedback: (35)
Thanks for the info guys....
Old 02-24-2004 | 05:54 PM
I run a 14x10 on my ASP 108 (older one). A 15x8 also works well. Higher pitch flies my GB Ultimate Bipe fairly fast, with decent vertical. Also cuts the noise somewhat. A 13" prop on a 108 sounds small to me.
Clair
