Thunder Tiger GP .42
I am looking for some break in, instructions for a TT GP .42 engine. The engine has only about 8 oz of 10% fuel through it. I just need some information on the correct way to break in this engine. Any information would be greatly appreciated. I do know that the engine was run on the rich side prior to me aquiring it.
Craig.
Craig.
RE: Thunder Tiger GP .42
ORIGINAL: Canuck1
Craig.
Craig.
My Feedback: (182)
If you don't have this, get it...10% nitro fuel with 20% lube (50/50 castor/synth is best); put an APC 9x6 on it. Start it and run the Hell out of it for two minutes...not full lean but a couple clicks richer than that. Then put an APC 10x6 on it, go to full lean and open the needle valve up about 4-5 clicks...run it through 2-3 eight ounce tankfuls at this setting...FULL throttle! OK...it's ready to go to a plane now.
