Magnum XL-91RFS Choke flap
1 Post
Do you need the choke flap on the carb of the 91 4 stroke?
None of my other 4 strokes have a choke, this looks like it doesn't do a whole lot apart from allowing you to close the carb for priming...
As the engine is going into a Tiger 60 I'll have pretty good access to it anyway. I have to cut the side cheek for the needle valve, if I leave the choke lever on I'll need to cut a deeper slot.
Any thoughts?
Any thoughts?
