Another Super Tigre question
My Feedback: (23)
FL
Hi! I used a 17-8 initially, and after about an hour of conservative running , I follow the philosophy of maximum swept area of prop disc for power . Start with 7 pitch and go up in diameter until you limit the rpm to about 7500 rpm. it will pull the bgeesus out of anything! rpm limiting also gets away from the minimal carb venturi problem. Lee N. Robinson [email protected]
