Effectiveness of Perry pump
Old 06-19-2002 | 01:08 PM
Default Effectiveness of Perry pump
I'd like to locate the fuel tank on a Venture 60/Saito .91 close to the CG, 10 inches or so from the engine. Will a Perry pump pull the fuel up that distance without pressurizing the tank? Any other ideas?
Old 06-19-2002 | 01:27 PM
I'm pulling fuel about 18 inches with perry pumps with no problem at all. Tanks are in the fuse and the pumps are mounted on the firewalls. Tanks are also about 7 inches below engines.
Tends to be a bit tough getting the first engine going, but by the time that one is running, the other starts right up.
Hans
Old 06-19-2002 | 02:25 PM
Perry pumps work great with Perry carbs. But when used with a standard two needle factory carb the mid-range tends to run rich. This usually causes poor transistion to WOT. Just my experience.
