Remote Glow Plug Ignitor
Old 04-05-2004 | 04:16 PM
My Feedback: (13)
Default Remote Glow Plug Ignitor
Question for you all, I want to be able to insert my glow plug ignitor into a fitting that will be on the outside of my fully enclosed/cowled engine. What part do I need and what exactly is it called. What are the different brands?
This is not an on-board glow ignition, just an ability to start my engine on the ground and then remove the ignitor.
Old 04-05-2004 | 04:40 PM
Default RE: Remote Glow Plug Ignitor
check out these DuBro items. other companies make them as well.
http://www2.towerhobbies.com/cgi-bin...glow&search=Go
Old 04-06-2004 | 05:03 PM
My Feedback: (13)
Thanks ShoestringRacer, I have an OS.52. Do you think I need the recessed unit or the standard unit? Or I suppose I could ask Tower when I order.
Old 04-06-2004 | 05:50 PM
coomarlin's Avatar
I use the unit from Model Products (aka Sullivan) and I think it sucks. The cap that locks onto the glow plug is constantly jiggling around and will not stay tight despite all that I've tried to fix it. I think the dubro one would be better. In fact, I've seen some homemade ones that I think look much better. I may cut the cap end of mine off and solder on some type of clip or maybe even a wheel collar to it. That way it will secure to the glowplug better.
Old 04-06-2004 | 06:45 PM
My Feedback: (38)
Hanger nine makes one part# 3025, i think
