more help with breaking in
Old 04-18-2004 | 12:44 PM
Default more help with breaking in
Hey, Guys,
Built a lot of planes and flown alot of planes. Haven't managed to land very many of them, though!! Anyway, I have yet another question about breaking in engines in gereral. Mostly two strokes, but four-bangers can get in on this as well. I have read Hobbsy's input, as well countless other posts, but my big qiestion is, how can I know if it's broken in at all, let alone properly? When I was growing up, (I'm 35 and cut my teeth on Goldberg Electras in 1990) you simply ran a couple tanks through it and pronounced the motor broken in. With my stellar record, (I DO manage to get my money's worth out of a kit!) I haven't given it much thought until now. But as I began to lust after more than bottom-of the-line garbage, I didn't want to make a mistake. I have read numerous posts of guys ruining engines with improper break-in. I got confused by all this.
For the record, I have irritated my neighbors this whole week by running motors I either haven't run or, haven't run more than once in years. Two 40LA's, a 46FX, a 25FP,
and a 52 surpass mostly. I run them rich as hell for a while. Lean them out for a minute or so (not at max, thought, but to get them warm). Then richen again and repeat. Not sure of my success, as I am successful if they continue to start!! They do, of course. Many of you have made me question my methods and not I need your help.
Please help me with any knowledge or input you think would assist me. I know this is a general question, but they do run the same basic way, don't they?! I am reading that a lot of manuals are wrong. That lean running will ruin. That rich running will ruin. Please help me out!! Sorry for the babble. Tying one on this fine San Diego morning overlooking scenic Tijuana!!
Thanks to all,
Bryan
Remember, Guys. He who spends the most time building will be the first to midair!!
Old 04-18-2004 | 12:52 PM
JoeAirPort's Avatar
My Feedback: (41)
Default RE: more help with breaking in
Do a search on "breaking in" or the motor name "46FX" etc, and you will find a huge data base on all of those motors listed. If you still can't find what you need come on back and ask some more questions. Lots of good people in this forum.
Old 04-18-2004 | 02:15 PM
DarZeelon's Avatar
Brian,
Answering to Joe, this is [link=http://www.rcuniverse.com/forum/m_704159/mpage_1/key_tapered%252Dbore/anchor/tm.htm#704159]one thread[/link] you will want to read very thoroughly.
With the exception of the Surpass, you broke all your other engines wrong! (the 'in' is omitted on purpose).
You should feel lucky if they all still have their nickel plating. About the fact that all these engines' pistons have been beaten smaller than needed; you should have asked sooner.
And since these are all engines from OS, you could have just gone to the [link=http://www.osengines.com/faq/product-faq.html#q2]OS Q&A section[/link] and seen the same thing there.
For ringed (and cast iron piston, steel sleeve) engines, rich is initially good, to seat the ring and to anneal it and the piston, with multiple heat and complete cool-down cycles.
For ABC/AAC/ABN engines, too rich is a killer; you just need a rich, two cycle setting, 300-400 lower than your eventual flight setting.
Old 04-18-2004 | 03:36 PM
Ring engines and ABC engines are broken in differently. Dar has written some excellent points on this in other posts if you do a search.
Old 04-18-2004 | 07:43 PM
Hobbsy's Avatar
My Feedback: (102)
The sky won't fall and your engines are not ruined, just run the AB? ones again a little rich and fairly fast and warm as Dar described. They'll be fine. 20 minutes or less will do the job.
