MDS 2.18 glow engine
CA
Can't close the throttle barrel to full close, because the carburetor barrel retaining screw groove in the throttle barrel is not long enough. Consequently, I have a very high idle. Also not permitting emergency stop if needed. Any body out there have any recomendations? Probably new carburetor, huh?
Respectfully Gary
Respectfully Gary
CA
Thanks for the information Luv Bipes. I knew old man Perry prior to his passing, and have used his products before. It's been years, and I completely forgot about his carbs. And now Conley has his business? Sounds good to me. Thanks again buddy.
Gary
Gary
CA
Hello Hobbsy:
Thank you for your input: This is what I like about RCU discussion forums. It opens minds and ideas. I'm thinking, if hobbsy wants me to take out two spring coils, why not take out the whole spring and see what happens. Low and behold, the same thing happens, I'm open about 3/16 of a hole in the venturi. Ah Ah. I dissassemble, look into the barrel chamber and see this screw protruding down. IT'S THE STUPID LOW IDLE SCREW ADJUSTMENT!!!!!!!! I back out the screw, reassemble, and now we have full throttle close.
Thanks again for the advice NAMYDNAH
