Wanted-Reliable .91 2 Stroke w/ Pitts. Possible?
NY
I am seeking a very reliable .91 size 2 stroke that can handle a pitts style muffler. I dont know if there is such a thing as I have never ventured past a .60 so far. I want to put it in a VectorFlight Extra 300S. I like the set it and forget it kind of engine as all my OS have been in the past with the basic care have served me well. I know others have had issues but I have been lucky so far. I dont want to chance a OS 91FX as I have heard way to many horror stories on that one. A smooth low to high end transition is important to me as well. Magnum makes a XLS .91A which has some merit. But I havent found a pitts for it yet. Any input from experience would be helpful.
My Feedback: (40)
NH
RE: Wanted-Reliable .91 2 Stroke w/ Pitts. Possible?
I have the Magnum .91 XLS in the VF Extra 66". I believe the exhaust outlet has the same mounting dimensions as the OS. Give BCM a call or e-mail and I'm sure they can fit you. I'm using the Jett Engineering in-cowl muffler, which hangs down lower than the Pitts style, requiring most of bottom of cowl to be cut out. This muffler is a little heavier than the BCM Pitts, but gives a significant power boost. I flew this engine hard all last year, found it to be very reliable. Get it with a couple extra head gaskets and use high nitro, your Magnum will love it.
MVVS .91 also a good choice.
My Feedback: (7)
I had a ST 90 w/ a Slimline "Pitts" in the nose of a WM Midget Mustang, That's a nice combo also.
ST's just take a while to break in. Save yourself some headaches, stay away from the OS 91FX!
You may also want to check out the GMS line of motors at Meccoa.com.
Gary
Gary
My Feedback: (19)
I have a lightly used magnum 91xls that is very reliable for sale in the marketplace. It was on a ohio yak but I wanted more power.
It has never dead sticked in the 30-40 flights I have on it. The OS 91fx can be reliable you just have to replace the needle valve. I have one of those as well and they turn the same prop at the same rpm. I have used both 10 and 15% nitro in both my 91's and did not see the need for head shims
