need piston ring for FS60 Help!
Old 05-15-2004 | 09:47 AM
misfitsailor's Avatar
Default need piston ring for FS60 Help!
Having trouble finding a piston ring for my new old FS 60 (open rocker) part#45067319
Is there a ggod source for obsolete NOS OS parts?
Old 05-15-2004 | 01:18 PM
Default RE: need cam set-screw for FS60 Help!
Misfit:
If we are thinking about the same screw, the one that holds the rear bearing to the cam, I think that was probably the most often replaced part on all the rear cam OS engines. People, trying to take it out, would tighten it and break the head off since it's a left hand thread, and instead of loosening it, it got overtightened and broke. I don't think anyone broke the second, though.
If you have, or have access to a small lathe that will buth cut metric and left hand threads, most likely the esiest thing will be just to make a new one.
Sorry I can't give any more encouragement.
Bill.
Old 05-15-2004 | 01:26 PM
Thanks, I now have a new cam set screw on the way (the only part still available from OS for this engine?) but I now am looking for a piston ring.
