Loud Muffler
I HAVE A TT PRO 120 WITH A J=TEC? PITTS MUFFLER. THIS MUFFLER IS LOUD. I WAS TOLD THAT IF I FILLED THE CHAMBER OF THE MUFFLER WITH STEEL WOOL IT WOULD QUIET IT DOWN. HAS ANYONE TRIED THIS? AND DOES IT WORK? :idea:
My Feedback: (16)
GA
It works but does increase the back pressure. The exhaust oil seems to build up on the steel wool and it gets messy. You could try a bigger propeller to decrease the RPM. This will make the engine and prop noises less.
My Feedback: (145)
Instead of steel wool, use one of those stainless steel drain traps. They are round and look like a donut. It is made out of a wire mesh and not so fine as to clog u. It does help with the sound. Still not as quiet as the factory muffler.
