MOKI 2.1 Question
Old 06-23-2004 | 11:05 PM
Default MOKI 2.1 Question
I have a new Moki 2.1 that has over a gallon through it. I am using a APC 22X8 and Bisson sports muffler.and can get 7500 RPM. The problem is at idle it is really rough. As l power up there is a ping ping ping sound untill abut half throttle. Sounds like pre-detination. Sometimes at idle it smooths right out, the way it should be and then starts to get rough again. Is it to rich at the low end. I tried turning it down, but it dies on me. It dies if l richen it as well. I have tried different plugs as well. I am using XP Sport fuel 10% nitro, 20% oil. Any ideas? Let it break in some more? To rich, or lean?
Tim
Old 06-23-2004 | 11:39 PM
Default RE: MOKI 2.1 Question
Nitro levels of 10% is high for the Moki . Try lowering it to 5% or get Fai fuel.
One gallon is still not enough . The engine will run better after 4-5 gallons.
Old 06-24-2004 | 06:35 AM
ben flyn's Avatar
I'm breaking mine in with a 20/8 prop. Only 3/4 of a gallon so far. No problems with idle; in fact it will idle so slow it's hard to stop with the kill switch. Your prop sounds to large for break in.
Old 06-24-2004 | 06:43 AM
PlaneKrazee's Avatar
My Feedback: (14)
Maybe too much prop, too much nitro, lean low end, I think.
I broke one in on a Mejzlik 20X8, 0% nitro, Cline regulator. It is an excellent engine and uses very little fuel if burning FAI fuel for the power it makes.
Old 06-24-2004 | 09:29 AM
I switched to a 20X8 and have the same problem. I have to go with 10%. I cannot find a LHS that will get me FAI fuel. And once they are out of 5%, that's it for the year. They don't sell enough to make it worthwhile. I can order some and have it shipped to me, but here in Canada it is considered dangerous goods and cost more to ship than the price of the fuel. I am sure the problem is in the low end needle. I will clean it out and start from scratch and let you know how it goes.
Tim
Old 06-24-2004 | 09:48 AM
Tim, just get the hobby shop to orer you a case (4 gallons) next time they order fuel. It won't take you too long to go thru a case if you fly much.........
Ed M.
My Feedback: (43)
go to a go kart or motorcycle shop and buy methanol and the proper oil, castor and synthetic and make your own fuel. While breaking in, I would run half castor, half synthetic with a total of 20% oil and balance methanol
Old 06-25-2004 | 01:24 AM
Dont disagree with anything above, the only thing I will add is that these Mokis take an age to run in.
They seem to keep getting better and better yet more docile at idle, I think you get the idea that I reckon they are great
Cheers
Phil
Old 06-25-2004 | 10:49 AM
LuvBipes's Avatar
Mokis will overheat and detonate w/ anything over 5% nitro - specially in summer temperatures (ask me how I know )
And 7500 rpm is about the right range for the 2.1, so I don't think that 22X8 is too big a prop. Mine spins an APC 20X10 happily at 7400 rpm with no overheating probs PROVIDED I keep the nitro to 5% or less.
Old 06-25-2004 | 02:35 PM
tonyc's Avatar
I agree with JeffH. You can mix a gallon of methonal with the 10% you have and that would cut you down to 5% nitro. You would have to add some castor oil to get the oil level back up to 20% but you should not have a problem finding methonal or castor where you are at.
I fly my Moki's on no nitro and 15% oil. The 20x8 prop is a better break in prop for the Moki.
tonyc
Old 06-30-2004 | 02:08 PM
Thanks for all of the answers guys and gals.
First of all the first post was a typo. It was a 20/10. Big fingers on the keyboard.
Unfortunately l live in a small town. No methanol and nothing under 10%. Nearest big city is 3 hours away and the two RC shops their will not get me FAI. SO l am stuck with 10%. A buddy in our club uses 10% and he has no probs at all. He tells me the nitro smooths out the mid range and he rarely uses full power. I will rarely need full power either. What else l found though is the carb is leaking fuel from the barrel. I took a new one off of my second MOKI 2.1 and 90% of my problems went away. I occasionally still get a pinging sound. But l think this may be from the way the engine is mounted. The plane is a aero works 300 profile. The engine is mounted between two hardwood mounts. So l am going to brace the mounting points with some aluminum, for a stiffer mount. See if that works.
So the next question is, where can l get Moki parts and/or repair services. I thought it was Gerard Enterprises. But they are no where to be found on the web.
Old 07-28-2004 | 08:02 PM
I have a Moki 1.80. I removed the piston to change the ring, and now I see there is a tab, in the ring groove to stop the ring from turning. The problem is, I do not know if the tab in the ring groove goes on the intake side port, or the exhaust. Clould someone please help.
