GMS 76 - Which Glow Plug?
Thanks Ed, I took up your suggestion and bought the GMS 76 instead of the 61. Same physical dimensions. My LHS suggested an OS A5 glow plug. Is this suitable for this engine? I have never used an A5 before, only A3, A8 and OS F. Any suggestions, guys?
Ed
Ed
My Feedback: (40)
NH
RE: GMS 76 - Which Glow Plug?
On my Tower 75, which is pretty comparable, I do well with a K&B L1, which is a hot plug. The OS A5 is a cold plug, for high nitro off-road racecar engines. I don't see how that would relate. If you want OS, I'd go with the A8, which is also rated hot.
I agree. The A5 would be too cold. You can tell because when you remove the battery, the rpm will drop a good bit. The A-3 would be a better plug or the OS #8. As has been mentioned, the K&B-1L is also good as it the Thunderbolt #3. I may be wrong, but it sure looks like the Tower Power plug is an A-3 with another label.
If you look at the coil and hole in the plug body, you can tell a hot or cold plug. Colder plugs have a small hold so the metal body is closer to the element (coil). This allows the heat to more easily transfer from the coil to the body, making it colder. Hot plugs have big holes. Next time you are at your local hobby shop take a look at the different plugs.
Don't forget to give your GMS 3 or 4 tanks of slobbering rich running, then run a smoke trail in the air for a while. Ringed engines do take a longer time to break-in compared to ABC types, but they will last a long time.
Thanks for all of that, guys, I will return the A5 and get an A8 and try the engine. Have not started it yet. Only got it yesterday! No guesses what I will be doing over the weekend!
If there is any other info/issues/setup procedures, etc. re this engine that you are aware of, please let me know. Always willing to learn from the experts. Thanks.
Cheers
Ed
Cheers
Ed
My Feedback: (40)
NH
Well, since you ask, I will recommend you get a bottle of castor oil from your LHS and add 4-6 oz to your first gallon, which can be either all castor lube (hard to find these days) or at least a blend of castor/synthetic. Ringed engines really need some castor in their regular diet, and especially so for the first gallon. As Ed says, run the first few tankfuls definitely rich; then after maybe 20-30 minutes of running, lean it out over several flights to 8000, then 9000, then 10000 rpm. As soon as the engine sings with a steady note, and with enough thrust to pull the plane, you can put it in the air--but be sure you have your low end set for a slow enough idle to land with. You will probably notice improvements in power over the first 5-10 gallons. My ringed engines seem to get better every year. I run them out of fuel at the end of the day, and work 10 drops of oil into the bearings.
